2004 Nissan 350Z Repair Question
Topics covered: Brakes, Mechanic, Brake pads.
Asked on July 28, 2010
2004 Nissan 350Z Brake Squeak - only when brakes heat up
Brakes problem
2004 Nissan 350Z 6 cyl Two Wheel Drive Automatic 35000 miles
I recently had both the front and rear brake pads & rotors replaced but I now notice a squeak when the brakes are applied; but only after the brakes heat up. I have completed the proper break in period although the mechanic who installed the brakes indicated that a break-in period is not necessary. I have returned the car several times to the mechanic, but to no avail. On the last visit the mechanic cleaned all brake parts including the calipers, he re-greased the bolts that the caliper slides on and he also used a rubberized coating on the back of each pad but the squeak remains. Any thoughts and or suggestions?
