2CarPros - Car Questions & Answers
1997 Nissan 200SX Repair Question
Topics covered: Engine, Fuel pressure, Sensor.
Asked on January 11, 2009
1997 NIssan 200SX Not getting fuel
Engine Mechanical problem
1997 NIssan 200SX 4 cyl Front Wheel Drive Automatic 22000 miles
Car was going down the road slowed down to turn and engine died. Tried numerous times to start it back up. Checked fuel pump pressure 65 lbs, pulled dist cap found screw holding rotor button had fallen out. Fixed this replaced with new rotor button and screw. Dist cap did not look damaged. Checked number one position timing looks to be in order. Doesn't seem to be getting fuel to the cylinders. Injectors seem to be working. Does have spark in spark plugs. Oh yeah replaced them also. Any ideas to what controls the fuel? Does cam position sensor control this? Where is the cam position sensor?
Avatar Asked by cowgirlup
Answer
Replied on January 11, 2009
That fuel pressure is way sky high-check the fuel pressure regulator and for a clogged return line.
At idle with vacuum should be 34psi and without vacuum 43psi
Tiny Answered by rasmataz
68 questions asked
