Mechanics
NEW CLUTCH, STILL CAN'T SHIFT.
1996 Ford Ranger • 145,000 miles
I replaced the clutch, pressure plate, and throwout bearing. However, it still will not go into gear, and grinds when I try reverse. When the clutch is pressed, the throwout is pressing the fingers in. So what could be causing it to not shift? And could the slave cylinder be bad if the throwout bearing is moving?
Kyboy_190proof
May 28, 2013.
Cadieman
May 28, 2013.
Replacing the slave cylinder should have been the first thing you did!
AD
Cadieman
May 28, 2013.
AD
