1988 Mitsubishi Starion Repair Question
Topics covered: Battery, Blower motor, Click.
Asked on November 23, 2009
1988 Mitsubishi Starion electrical system acting goofy
Electrical problem
1988 Mitsubishi Starion 4 cyl Two Wheel Drive Manual 88000 miles
the car started and ran fine with brand new battery 2 months ago, battery was then removed from car and put in garage. charged battery yesterday ( pulled 5 amps 4 2 hrs) then put it in car and starter easily turned over engine but no ignition..while the key was turned in the ignitiion the wiper blades wouldn't stop moving, the radio wouldn't work and the blower motor never stops turning and the automatic temp control doesn't light up (not working?) I started paying with the battery posts and noticed when putting the positive post back on a clicking sound comes from a relay on the fire wall (maybee Voltage regulator??) well today I figured I would go out and look at it again..I thought I had disconected the battery but I guess I forgot...no power to car at all now, put battery on charger and it pulls over 50 amps off scale!!! blows trip on charger after 30 secends and charger kicks off, it did this twice (I have expensive 2 setting charger Start 50 amps and general charge) I thought the charger had a problem but when i hooked it up to the battery in my other car it charged fine 8 amps. Whats going on here? did the relay/vo;tage regulator on firewall fail causing goofy car electrical probs?? but whats with the battery?? Any help appreciated Tony
