2012 Mitsubishi Other Repair Question
Asked on December 17, 2006
Clutch pressure 3000GT Mitsubishi
Hi, today while driving my clutch started loosing pressure, by the time I got home it had no pressure. I noticed the master cylinder fluid was empty, so I got some DOT 3 fluid and filled it. I tried putting the car in gear, but there was still no pressure when I pushed the clutch in, actually the pedal stuck when I pushed it all the way to the floor. I'm going to take it into the shop in the next few days. I was just wonder if anyone could give me some help with this problem. Thanks
Answer
Replied on December 17, 2006
There has to be a leak somewhere between the master cylinder and slave cylinder. Should find some DOT 3 all over something.
Good luck,hope that helps.
