1992 Mitsubishi Montero
Engine Cooling problem
1992 Mitsubishi Montero 6 cyl Four Wheel Drive Automatic 136000 miles
I was wandering if you could tell me where I could be leaking on the back of the motor. It started on the warmest day here when the temp reached 80. My thermostat stuck closed, and we replaced it; but I was seeing antifreeze on the ground. It's gotten worse over the last couple of days and it seems to only leak when the engine is in drive. I'm stumped. We put new head gaskets and heads on it three years ago, and a new radiator two years ago. It's not blowing white smoke, or anything that signals a possible head gasket leak. If you please help me in the matter i'd appreciate it.
Thank you
Sheana Marie
April 6, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
