1999 Mitsubishi Mirage
Shakes or Wobbles problem
1999 Mitsubishi Mirage 4 cyl Front Wheel Drive Automatic 179000 miles
My car is a 1999 Mitsubishi Mirage with 179000 miles, recently I've been having a vibration when Im at a red light with the car in drive, its really bad when the ac is on. It will shake even worse when I have to make a sudden stop and the ac is on. I tested the motor mounts with the car in drive, pressed on the brakes and the accelerator at same time, the engine moved but not a whole lot. Also when I shift to park, reverse or neutral the vibrations stop. Could it still be my mounts are could it be something else?
September 24, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
