Mechanics
MITSUBISHI MIRAGE WHEEL PROBLEM
1995 Mitsubishi Mirage
Brakes problem
1995 Mitsubishi Mirage 4 cyl Front Wheel Drive Manual 95000 miles
Hi
2 months ago I have changed rear wheels break shoes and break cylinder on right side because it was slightly leaking. Break system was bleeded with 2 persons. Everything is OK, just wondering why is the rear right side always warmer by 20 (roughly) degrees of celzius than the left side. Of course how much warmer it is depends how much I use breaks.
It is never so hot that I could not hold my fingers on the drum though.
I have checked rear wheel bearing on both sides and there is no grease at all. Is Castrol LM good for that?
Hom much should I put in?
Thanks in advance
Juraj
Jcikkel
July 8, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
