Mechanics
THERMOSTAT
2001 Mitsubishi Eclipse
Heater problem
2001 Mitsubishi Eclipse 6 cyl Front Wheel Drive Automatic 110000 miles
I NEED TO INSTALL A NEW THERMOSTAT. I HAVE THE CHILTON MANUAL BUT AM CONFUSED BY THE DIAGRAM AND INSTRUCTIONS. I HAVE REMOVED THE HOSE AND DON'T SEE THE HOUSING.
CAN YOU GIVE ME ANY HELP? I HAVE TRIED TO FIND A BETTER DIAGRAM ON-LINE.
Nancy hylind
February 9, 2009.
I just changed mine it's a V-6 tho. They are tricky to get to but it's not that hard to do. It's on the right side of the motor when your looking from the front of the car but it's under the air filter hose wich has to be unsnapped and held aside it's also underneith another cluster of wires and a plastic cover that must be un screwed to get to it and there are 3 bolts holding it in. Hope this helps a little.
Tyler40729
Feb 11, 2009.
AD
