Mechanics
CHECK ENGINE LIGHT
1997 Mitsubishi Eclipse
Engine problem
1997 Mitsubishi Eclipse 4 cyl Wheel Drive Type unknown Automatic 100000 miles
we fixed the problem, and tried disconnecting the battery. Now we need to know the drive cycles to make it reset.
Arfaught
January 23, 2008.
Rent an scanner at your local autoparts (autozone) they rent it for free and " erase" the codes, disconnecting the battery wont erase the codes, you should use the command of the scanner.
Good Luck.
Fisherman
Jan 23, 2008.
AD
