1996 Mitsubishi Eclipse
Transmission problem
1996 Mitsubishi Eclipse 4 cyl Front Wheel Drive Automatic 112, 00 miles
I have a 1996 Mitusbishi Eclipse 4 cyl. That started leaking transmission fluid. It looked to be coming from the seal between the CV joint and the transmission so I changed that seal. It still leaked after changing the seal so I changed it again. Still, it's leaking from the same area. The transmission fluid pan is dry, but it's still slinging transmission fluid. Any idea of what it could be or what I could check next?
March 25, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
