Mechanics
COMPRESSION
1990 Mitsubishi Eclipse
Engine Performance problem
1990 Mitsubishi Eclipse 4 cyl Front Wheel Drive Automatic 256000 miles
MY CAR WILL TURN OVER BUT WONT START AT ALLCOULD YOU TELL ME WHY THIS COULD BE HAPPENING
TIPTOE TWO
November 1, 2010.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Rasmataz
Nov 1, 2010.
AD
