Mechanics
OIL LEAKING
1999 Mitsubishi Diamante
Engine Mechanical problem
1999 Mitsubishi Diamante 6 cyl Two Wheel Drive Automatic 172400 miles
I have recently noticed a bit of oit leaking from the oil filter side of the motor. I know its not the oil filter it's coming from above it. I took the timing cover off to see but I can't tell. There are a few bolts that have worked loose so I tightened what I could. It's leaking about 1qrt every 2 wks. What's your thoughts? Thanks Brian
Briansmalley
January 11, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
