Mechanics
LOST POWER
1999 Mitsubishi Challenger
Engine Performance problem
1999 Mitsubishi Challenger 4 cyl Four Wheel Drive Manual 110k miles
hi and thanks for your help
i have mitsubishi challenger 2.5 tdi am not gating full power it revs normal but when driving its not speeding up a way it normal dos. Drives on high rpm and no sped.{ Gear box is good mister clutch checked } dos not no smoke.I got a turbo on ebay and there is a play on the turbo shaft but every thing else looks good on it but the car sounds and drives like non turbo car. Actuator works normal. There is a pipe what comes close to outlet manifold and it gos on the right said of actuator and it looks like actuator and is small pipe connected to it what it socks air from that part { I can hear a little rattle }the small pipe gos to 1 sensor what is powered up { can inter cooler make the car loose power } and play on the turbo shaft make turbo not to work } you help is much appreciated thank you
Ben28
January 18, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
