Mechanics
TRANSMISSION OR POWER STEERING RUNS WHEN
2005 Mini Cooper S
Electrical problem
2005 Mini Cooper S 4 cyl Front Wheel Drive Automatic 51000 miles
THERE IS A MOTOR THAT RUNS EVEN WHEN THE CA R IS TURNED OFF. THIS PROBLEM JUST STARTED 2 DAYS AGO. I THOUGHT THAT THE BATTERY HAD WENT BAD, BUT ACTUALLY IT RAN DOWN BECAUSE THE MOTOR OR PUMP CONTINUES TO RUN EVEN THOUGH THE CAR IS NOT ON. I CHECKED FUSES IN THE FUSE BOX THEY LOOK FINE. I THOUGHT THAT IT MIGHT BE THE SMALL FAN ON THE BOTTOM OF THE TRANSMISSION, BUT THE FAN WAS NOT TURNING BUT A PUMP OR SOMETHING ELSE WAS. CAN YOU HELP ME WITH THIS PROBLEM?
Jhackler
February 23, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
