Mechanics
WON'T START
2003 Mini Cooper S
Engine Mechanical problem
2003 Mini Cooper S 4 cyl Two Wheel Drive Manual 94xxx miles
the battery is good.
Jeffreyb88
December 17, 2009.
What is it doing? Is it cranking over and will not start or just won't crank at all/nothing/nada-
Rasmataz
Dec 18, 2009.
When I push in the clutch and turn the key I hear one small click from the engine compartment and then nothing.
Jeffreyb88
Dec 18, 2009.
Load test the battery if okay double check connections-the following components could cause your problem, starter, starter relay, clutch switch and ignition switch
AD
Rasmataz
Dec 18, 2009.
It started. But I didn't do anything. It sat for a whole day and then it started. I'm thinking this must be an electrical issue. What do you think?
Jeffreyb88
Dec 19, 2009.
AD
