Mechanics
SHOCK ABSORBER OIL
1980 MG MGB
Suspension problem
1980 MGB 4 cyl Two Wheel Drive Manual 180000 miles
I'm trying to figure out where to add oil to my shock absorbers on the front suspension system and I have no clue. Not even the manual has any information on where to add or check for oil levels, just that I should check it. If you could point me in the right direction I would greatly appreciate it.
BVINSON89
June 3, 2009.
On the top of the shock there will be a plug facing the tire. That is where you put the oil. If you have a squeeze bottle filled with oil that will be the easiest.
Hmac300
Sep 9, 2009.
AD
