1999 Mercury Villager Repair Question
Asked on December 18, 2007
Rear cargo lift gate repair
Other Category problem
1999 Mercury Villager 6 cyl Two Wheel Drive Automatic 75000 miles
I want to repair the very small dent on the lift gate by removing the molding Interior cover. How can I remove the cover from the back.
Is it screwed down to the frame of the lifting door or pressed fit to the frame?
If the cover can be removed then I can access the door from the back and can make the dent repaired.
I need to just push it out from back.
