1997 Mercury Tracer Repair Question
Topics covered: Spark, Fuse, Ignition coil.
Asked on April 15, 2010
1997 Mercury Tracer no spark
Electrical problem
1997 Mercury Tracer 4 cyl Front Wheel Drive Automatic 100000 miles
Have replaced, ignition coil, spark plugs, plug wires, crank shaft pos. sensor. I have checked all fuses
I still have not been able to get any plugs to fire.
What else can i test or replace or try.
Answer
Replied on April 15, 2010
Ok so I must ask have you checked to see if the timing belt is not broke? If it is broke or bad the cam will not turn and you will not get spark. Let me know what you find.
