1995 Mercury Tracer
Electrical problem
1995 Mercury Tracer 4 cyl Front Wheel Drive Automatic 154000 miles
My windows suddenly stopped working, i've tried replacing the combo switch but I got nothing from it. Im getting power to the fuse block and the fuse is good but i'm not getting power to the switch or the motor, I think there might be a break in the harness going from the door to the fuse block. My question is: are there any grounds that might be messed up and causing this or is it more likely a break in the harness. The more I look at it, the more I really don't want to mess with it because it looks like to check I would have to strip the door and remove it. Also i'm having problems getting a plug wire on the plug. I think its cylinder #1, its behind the altenator, do you have any tips on getting this on.
April 21, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
