Electrical problem windshield wipers are not working
2003 MERCURY SABLE
155,000 MILES • 0.5L • V6 • FWD • AUTOMATIC
MICHAEL GRAHAM
The window,s speedometer, windshield wipers, and my inside lights do not work. I have changed all the fuses and still everything is not working. I have been having this problem now for two weeks now and I am trying to get it fixed. but I cannot find the problem. can you please help me?
Jan 31, 2014 at 3:21 AM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
i would say that you have a problem either with your general electronic module (GEM) or communication between it and the PCM. all of the things you are having problems with are controlled by the GEM except the speedometer. it may be unrelated. maybe a speed sensor or an actual bad speedometer. it is controlled by the PCM. fix the other problems first and it might all fall into place.
Jan 31, 2014 at 4:17 AM
MIKEGRAHAM
the windows, inside light, windshield wipers and speedometer do not work. i have changed all fuses and still nothing works. I would like to know what it is that has made everything stopped working? I do not know if it is electrical sensor or what? I just cannot seem to get the problem fixed. someone please help! i do not know if it is the fuse called the power point.
Jan 9, 2017 at 5:39 PM (Merged)
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
I am not sure what the power point fuse is for. However, is it good? Also, have you checked the main fuses under the hood?
Jan 9, 2017 at 5:40 PM (Merged)
CASUAL
Six cylinder front wheel drive automatic 81,000 miles
I recently was fooling around with one of the windshield wipers and it stopped working (passenger side). The other one works fine. Any suggestions on a cause of this predicament?
MASTERTECHTIM
  • 4,750 POSTS
either the linkage popped off, or the bolt holding the wiper arm is loose. check at the base of the arm, there is probably a black plastic cap. pop it off and tighten the nut with a 13 mm socket or wrench.
CHUCKHRGR
Six cylinder front wheel drive automatic 55,000 miles
When engaging the wipers they do not work on high speed and work on and off when on low speed. Tried replacing the wiper switch on the column only to find that they do not work at all now. Any suggestions and do you think the wiper motor needs replaced?
TGCERESE
i want to check the fuse before anything i have to book. i just need a diagram of the fuse box so i know which fuse is for the windshield wipers. or how many amps the windshield wiper fuse is.
