Electrical problem windshield wipers are not working
MICHAEL GRAHAM
  • 2003 MERCURY SABLE
  • 0.5L
  • V6
  • FWD
  • 155,000 MILES
The window, s speedometer, windshield wipers, and my inside lights do not work. I have changed all the fuses and still everything is not working. I have been having this problem now for two weeks now and I am trying to get it fixed. But I cannot find the problem. Can you please help me?
Friday, January 31st, 2014 AT 3:21 AM
KNOWLEDGE IS POWER
  • 1,136 POSTS
I would say that you have a problem either with your general electronic module (GEM) or communication between it and the PCM. All of the things you are having problems with are controlled by the GEM except the speedometer. It may be unrelated. Maybe a speed sensor or an actual bad speedometer. It is controlled by the PCM. Fix the other problems first and it might all fall into place.
Friday, January 31st, 2014 AT 4:17 AM
MIKEGRAHAM
  • 0.5L
  • V6
  • FWD
  • MANUAL
  • 155,000 MILES
The windows, inside light, windshield wipers and speedometer do not work. I have changed all fuses and still nothing works. I would like to know what it is that has made everything stopped working? I do not know if it is electrical sensor or what? I just cannot seem to get the problem fixed. Someone please help! I do not know if it is the fuse called the power point.
Monday, January 9th, 2017 AT 5:39 PM (Merged)
  • 108,170 POSTS
I am not sure what the power point fuse is for. However, is it good? Also, have you checked the main fuses under the hood?
Monday, January 9th, 2017 AT 5:40 PM (Merged)
CASUAL
  • 2002 MERCURY SABLE
  • 6 CYL
  • FWD
  • 81,000 MILES
Six cylinder front wheel drive automatic 81,000 miles
I recently was fooling around with one of the windshield wipers and it stopped working (passenger side). The other one works fine. Any suggestions on a cause of this predicament?
MASTERTECHTIM
  • 4,749 POSTS
Either the linkage popped off, or the bolt holding the wiper arm is loose. Check at the base of the arm, there is probably a black plastic cap. Pop it off and tighten the nut with a 13 mm socket or wrench.
CHUCKHRGR
  • 6 CYL
  • FWD
  • 55,000 MILES
Six cylinder front wheel drive automatic 55,000 miles
When engaging the wipers they do not work on high speed and work on and off when on low speed. Tried replacing the wiper switch on the column only to find that they do not work at all now. Any suggestions and do you think the wiper motor needs replaced?
TGCERESE
  • 2001 MERCURY SABLE
I want to check the fuse before anything I have to book. I just need a diagram of the fuse box so I know which fuse is for the windshield wipers. Or how many amps the windshield wiper fuse is.
