Radiator removal
2002 MERCURY SABLE
80,000 MILES
MONEYSAM
  • 173 POSTS
I want a step by step procedure on removing the radiator on this vehicle
Sep 29, 2012 at 2:21 AM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-replace-a-car-radiator
Sep 29, 2012 at 8:54 AM
MIAMI HEAD
How to remove radiator 2002 mercury sable?
Nov 11, 2019 at 6:58 PM (Merged)
  • 54,350 POSTS
Hey Miami Head,
Remove the battery and battery tray. For additional information, refer to BATTERY, MOUNTING & CABLES .
Drain the cooling system.
Disconnect the upper radiator hose.
Fig 2: Disconnecting Upper Radiator Hose. Disconnect the degas return hose.
Fig 3: Disconnecting Degas Return Hose. Using the special tool, disconnect the upper transmission cooler line.
Fig 4: Disconnecting Upper Transmission Cooler Line Using Special Tool. Remove the two A/C condenser retaining bolts.
Fig 5: Removing A/C Condenser Retaining Bolts. Raise and support the vehicle. Remove the radiator support bracket bolts and the radiator support bracket.
Fig 6: Removing Radiator Support Bracket Bolts And Radiator Support Bracket. Disconnect the lower radiator hose.
Fig 7: Disconnecting Lower Radiator Hose. Disconnect the lower transmission cooler line. Remove the two bolts retaining the condenser to the radiator.
Fig 8: Removing Condenser-To-Radiator Bolts. Secure the A/C condenser. Remove the bolt retaining the P/S cooler to the radiator.
Fig 9: Removing P/S Cooler-To-Radiator Bolt. Remove the nuts and the radiator support brackets.
Fig 10: Removing Radiator Support Brackets Nuts. Remove the radiator from the vehicle.
Fig 11: Removing Radiator From Vehicle
Here is a guide that will help show you what you are in for with this repair.
and
https://youtu.be/Boi0DPXVHbM
There is also diagrams below.
Please let us know happens so it will help others.
Best, Ken
ANDREWAITE1
what steps must be taken when removing the radiator out of a 2000 sable do I have to remove the gray plastic piece around the fans
BMRFIXIT
  • 19,053 POSTS
Radiator
Special Tool(s) Fuel Line Disconnect Tool Set
310–S039 (T90T–9550–S)
Removal and Installation
To install, reverse the removal procedure.
PEACHA
Hello, I'm hoping you can help me in diagnosing my sables problem. My sable has 148,000 miles and has been an excellent car. Last fall my heater quit working and I parked it for the winter because the mechanics I took it to said that it wasn't the therm. and it probably would be expensive to fix. Yes, these were shadetree mechanics. Anyway, I recently pulled my sable out of the garage and started checking and replacing fluids and such before I started to drive it. My check engine light is on, and stays on. My radiator is foaming brown stuff. I had a neighbor flush the system and I added new antifreeze, but it still flows over the foamy brown stuff. The car seems to run just fine but I am afraid that if I continue to drive it I will end up killing it. Can you give me some suggestions what it might be? Thanks so much!
LOSONE
  • 1,616 POSTS
Humm when a radiator does that it is usually a blown head gasket. If you rev the engine does it spill more stuff?? If so a pricy fix.
YNOTTONY
Engine Cooling problem
1998 Mercury Sable 6 cyl Front Wheel Drive Automatic
I need to know how to remove and install a radiator on a 1998 mercury sable.
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2167.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_701.jpg
