1998 Mercury Sable Cruise Control
1998 MERCURY SABLE
135,000 MILES • 6 CYL • FWD • AUTOMATIC
BRAVESTAR1
  • CAR REPAIR CONTRIBUTOR
  • 234 POSTS
I normally can work on most anything when it comes to a car. Except electrical, which is most vexing for me.
My Cruise Control will not come on. One day it just stopped working. I checked all the fuses, but none of them are listed for the cruise control, and none of the ones checked showed any broken fuses.
I swapped out the Cruise control computer on the motor unit that's mounted on the side of the left strut tower, but still no power to the unit. (I.e. the Cruise light doesn't come on).
I think it's the switch on the steering wheel or a fuse somewhere. What position/location would the fuse for the CC be? Also how do you remove the switch on the steering column without blowing the airbag all over yourself?
Jan 20, 2009 at 12:19 AM
RACEFAN966
  • 5,029 POSTS
Ok we will do some tests to see if the buttons are working but first I need to know if you have a digital multi meter? It has to be digital as the computer system does not like using anolog type. Get back to me with that and we will do a couple of test to determine if it is the wheel or the vss (vehicle speed sensor) or the brake light switch ok.
Jan 20, 2009 at 10:01 AM
BRAVESTAR1
  • 234 POSTS
I don't have a multimeter anymore. I did have an analog one, but it didn't work very well. I will get one of those as soon as possible.
I checked with my local Ford dealer today, and they were unable to help, as it's an older vehicle (+10) years. I guess if I had tried last November I could've gotten some help.
I'll get back to you on the multimeter.
Jan 20, 2009 at 3:48 PM
RACEFAN966
  • 5,029 POSTS
Ok make sure it is a digital as the computers don't like anolog type. It does not have to be a fluke or anything like that just a one that has volts and ohms and such a 25 dollar one works just fine. Once you have get back to me and we test the system.
Jan 21, 2009 at 10:17 AM
BRAVESTAR1
  • 234 POSTS
I have it. Got me one for $23 at Lowe's last night.
Course on the way home, a brake line on another car went by-bye's, so I'm dealing with that as well.
But anyways continue. I did get a Digital one, as I never could understand the analog ones anyway.
Jan 21, 2009 at 7:14 PM
RACEFAN966
  • 5,029 POSTS
OK first things first lets see if the car will tell us where to look first ok. The steps I am going to give you will make the car do a self test of the cruise and give us any codes to get to a place to start ok.
1) Put the car in park and set the e-brake do not put you foot on the brake pedal. Now while holding the cruise off button turn the key to the run position (key on engine off). The cruise light on the dash should flash once to tell you it is self diagnostic mode. If it don't flash then repeat.
2) Release the cruise off button and within 5 seconds press the cruise on button. Now press the remaining buttons in this order. ON,RES,,COAST and SET, and ACCEL. As you press the buttons the CRUISE light will flash, Wait till the light goes out to press the next button. After you done doing this test and all the buttons have been pushed the CRUISE light will flash you need to count the flashes. Once that is done the car will do a throttle test and will open the throttle just a touch. Once that is done then the self test is complete and you can turn off the key. It will flash 1 to 5 times. Get back to me with the number of flashes and we go from there.
Jan 22, 2009 at 10:28 AM
BRAVESTAR1
  • 234 POSTS
So I tried that.
I got in the car, brake on, and held "off" button for 5 seconds, turned car to run, then hit the "on" button, then the "on" button again and each time the Cruise light flashed once. However upon each attempt at getting the "Resume" button to get the light to flash, nothing happened.
I wonder if I wasn't supposed to press the "on" button twice, as indicated earlier. I will try that in a bit as soon as I warm up.
Jan 23, 2009 at 2:40 PM
BRAVESTAR1
  • 234 POSTS
You gotta do this fast, and get it done rather quickly, like playing SIMON.
But anyways it was only one pressing of the "On" button, and everything else worked (so I don't have to replace the buttons).
Subsequently, I received "1" blink extra. I did it three times to make sure, and it was most definitely, a 1.
Jan 23, 2009 at 7:39 PM
RACEFAN966
  • 5,029 POSTS
That is great that means it passed that is what the one blink means so it is getting all the inputs from the wheel and the cruise module understands it. Now we need to test the VSS Vehicle speed sensor. I am thinking that may be your problem as to why it won't work. Are you ok with doing some tests on the ABS unit and such? Let me know and we go to the next step.
Jan 24, 2009 at 9:24 AM
BRAVESTAR1
  • 234 POSTS
Here's the funny part to that answer.
I'm comfortable testing anything. Unfortunately I don't have ABS. Yes it listed that the car had anti-lock brakes on the thing when the 2nd owner bought the car, but when I went to do a brake job, I found no wheel speed sensors, no ABS light, and no toothed rings on the driveaxles. So no ABS. And it's an LS Premium. What the premium stands for is anyone's guess.
Jan 24, 2009 at 10:17 AM
BRAVESTAR1
  • 234 POSTS
When I was doing this sequence of instructions I got to thinking. Maybe your only supposed to press the Set/Accel button once.
So the sequence is: hold Off, (turn key to on) Then press "On", "Res", "Coast", then the "Set/Accel" button once each.
Doing it that way, I get 3 flashes. Now here is the caveat. Is it a flash plus 2 flashes to indicate you pressed the correct button, or is it 3 flashes to indicate the unit is flashing 3 times once you press the final button. Pressing the Set/Accel button twice as originally indicated caused the single flash to occur, which may have inadvertently cancelled the self-test.
As far as the throttle opening up, I have not sensed that, since of course the car is essentially off, and you can't really hear it from inside the car.
Jan 25, 2009 at 6:30 PM
BRAVESTAR1
  • 234 POSTS
So anyways I checked around, and 1 flash means nothing except that everything works.
I got 3 flashes, and that is the Brake Deactivation Switch circuitry and the possible cause is a failure of the Brake Pressure Control Valve.
Now before I get to replacing stuff I don't need doing, where is this stuff, and how hard are we talking. The horn works that I know of, and so do the brake lights.
Jan 25, 2009 at 6:39 PM
RACEFAN966
  • 5,029 POSTS
Ok now we are going to do a brake input test to the cruise module. First disconnect the harness from the cruise servo next to the master cylinder now check for voltage between a good ground and term number 9. If more then 10 volts then replace the servo as it is bad. If less then 10 volts then disconnect the deactivate switch at the brake pedal and check for voltage at the light green and red wire and gound (using you multi meter) if less then 10 volts then there is a short in that wire. If more then 10 volts then check the OHMs of resistance between the tan and orange wire at the brake pedal and the cruise servo term number 9 if less the 5 ohms then replace the brake switch if more 5 ohms then fix the short in the tan and orange wire. Here is a pic of the cruise control connector so you will know which term number is which. Let me know how it goes.
https://images.2carpros.com/forum/automotive_pictures/249564_Graphic_30.jpg
Jan 26, 2009 at 3:37 PM
BRAVESTAR1
  • 234 POSTS
At the moment it's freezing rain outside, so hanging outside under the hood for the cruise control has had to take a back seat to brake lines that need doing. But I will get back to this this weekend.
Jan 28, 2009 at 7:46 PM
RACEFAN966
  • 5,029 POSTS
Ok that fine. I understand that as we get that here where I live too and it sucks. Get back to me when the weather breaks and you feel like getting back to it and we test the Vehicle Speed Sensor and the cruise servo ok. Thanks again and hear from you later.
Jan 29, 2009 at 10:32 AM
TAVOUGHN
Im having the same problem my cruise control light wont come on I did the test pressed each button once it flashed each time once but when I stop and try to get it to work the cruise control light wouldn't come on
Jan 30, 2009 at 8:16 PM
BRAVESTAR1
  • 234 POSTS
I got caught up repairing another car (see questions related to a 1994 Buick LeSabre)
I had to replace practically all the brake lines, all the fuel lines near the fuel filter, and the transmission cooler lines, all the while working in a very cold garage, and trying not to set myself on fire. Add to that, it had this quirk where I had to take it to a garage to use a Tech1 Scan tool to get the air out of the ABS Pump, and the dang bleeder screws/wheel cylinders in the back rusted up.
Fixed that, and low and behold a hole (about the size of my fist -no relation) opened up in the rear tirewell where I replaced all the lines for fuel and brakes. So I'm not just getting back to my original question, and the problem therein. I hope to have some resolution this weekend.
Feb 6, 2009 at 1:18 AM
BRAVESTAR1
  • 234 POSTS
[quote:9e696b179c="Tavoughn"]Im having the same problem my cruise control light wont come on I did the test pressed each button once it flashed each time once but when I stop and try to get it to work the cruise control light wouldn't come on[/quote:9e696b179c]
So you managed to get the Cruise Control Self-Test to work then? Which means the light works.
What your problem is, the Cruise light will only come on and stay on, if the system is working. Do the self-test again, in the correct sequence, and tell us how many flashes you get.
Feb 6, 2009 at 1:20 AM
RACEFAN966
  • 5,029 POSTS
So how did it go?
Feb 6, 2009 at 10:34 AM
BRAVESTAR1
  • 234 POSTS
I definitely could've used a helper for this one.
On the Servo check, I could only muster about 1 volt or less, I was never sure it was connected as I had to use a paper clip to slide into the tiny slot of the harness.
So I moved on to the deactivate switch and found that to be at 10.5 volts. Which is good considering there is a break in the wires where i had to replace the old brake switch in order to get the taillights to work, and the Shifter to disengage.
I'm working on the OHM's test. A bit of a challenge as I can't hold the two leads without help, and it's after 9pm.
Feb 6, 2009 at 11:22 PM
RACEFAN966
  • 5,029 POSTS
Ok get back to me when your done that is fine. Did you get to the ohms check? Get back to me.
Feb 7, 2009 at 9:14 AM
BRAVESTAR1
  • 234 POSTS
The wire showed .02 Ohms twice.
The first time I tried it, I used a paperclip to extend the inside of the connected from the servo, and it wildly fluctuated from -1 to 150, so I think the paperclip was to blame on that. After retesting twice I got .02 both times.
One thing to note, I had the car out of the garage, and went to put it in, and the shifter was very hard to remove from park. Thus the brake switch is to blame, and needs to be replaced just to get the car to work.
I replaced this before, but from the junkyard, guess sometimes things have to be bought new.
I do have another semi-related question for you. Under there, I found a bank of relays, that I can't find an explanation for. There are 4 slots, with 3 relays occupying 3 outta 4 slots, and it's got a cover upside down, but no idea what they are for.
Sometimes when the car doesn't start, I swear coming from there, is this rapid clicking sound. I get the feeling one of them isn't so swift, but I can't tell what they are for, as I disconnected them, and could still drive the car fine.
Feb 7, 2009 at 9:34 PM
RACEFAN966
  • 5,029 POSTS
Can you include a pic of the relay's with the cover off but in the pic and tell me where this relay box is located and I will look to find what they do.
Feb 9, 2009 at 10:10 AM
BRAVESTAR1
  • 234 POSTS
Sure, let me get my camera.
Feb 9, 2009 at 10:43 AM
BRAVESTAR1
  • 234 POSTS
Had to shrink it down a lot, but this is a general idea. That metal thing is the steering knuckle.
https://images.2carpros.com/forum/automotive_pictures/180565_Relay_Close_1.jpg
https://images.2carpros.com/forum/automotive_pictures/180565_Relays_Closeup_1.jpg
Feb 9, 2009 at 11:27 AM
BRAVESTAR1
  • 234 POSTS
....in the meantime I decided to do a tune-up.
Which means you have to remove the upper manifold, and then I broke 2 bolts doing so, cause the dang things are so cheap, they snap off.
Any idea on how to keep this from happening in the future?
I'm going with Motorcraft OEM "Platinum" Spark Plugs, so hopefully I don't have to change them out for 100K miles. It's so dirty on the intake manifold I figured I'd clean those too with carb cleaner and a wire brush. I might have it all done this week.
It's all fun. Oh I found another 3 relays, on the outside by the battery box. Can't remove the cover though as you'd have to remove the battery box to undo the cover for it. Dumb, really dumb. Who thinks of these things?
Feb 9, 2009 at 1:46 PM
RACEFAN966
  • 5,029 POSTS
So these should be Door lock relay, Door unlock relay and flasher relay. Nothing to do with the running of the car. As for the bolts that broke I would anti seaze them unless there are in a water jacked area then I would use thread sealer.
Feb 9, 2009 at 8:12 PM
BRAVESTAR1
  • 234 POSTS
Well that's good. Next time I can't get in the car, I'll know the reason why.
Feb 11, 2009 at 10:02 AM
RACEFAN966
  • 5,029 POSTS
Yes you will. thanks and let me know how it goes.
Feb 11, 2009 at 10:08 AM
BRAVESTAR1
  • 234 POSTS
So I did a full tune-up and replaced out the standard plugs and put in Motorcraft platinum plugs, in order to fix what I felt was a retarded ignition that, as I fully see was carbon/tarnish build-up everywhere. Sprayed the whole thing out with 2 cans of carb cleaner, and finally got it all started again.
Well it initially wouldn't shift out of park. I thought the switch I replaced was the one to do it. And I was right. I was looking at another person's question from Oct 2008 that mentioned the plastic pushrod switch above that must control the brake lights themselves, and since I didn't have lights on, that this must be the case. Fortunately all it turned out to be was a blown 15amp fuse.
So....it works. The car drives, and the cruise control works. Best of all I got the part from the junkyard cause I had to go there to get replacement long-stem bolts for the intake manifold that I broke while changing out spark plugs that didn't need changing, cause I put Platinum ones in the rear, and el-cheap-o's in the front, and that's why I was having a bad spark and the engine was running rough....oh the lessons learned today.
So the moral of the story is. You can use used parts, provided your willing to take the risk, but in some instances it's best to go with new stuff, and the premium stuff cause it well just work better in the end.
Thanks for your help.
Brett
Feb 12, 2009 at 12:43 PM
RACEFAN966
  • 5,029 POSTS
Great I am glad it all worked out and that it is now running. Thanks for the update and have a great day.
Feb 14, 2009 at 1:29 PM
