spark plug wiring order
2001 MERCURY SABLE
6 CYL • 2WD • AUTOMATIC
MARCOS7449
  • 5 POSTS
2001 mercury sable 3.0 24v spark plug wiring diagram
Mar 21, 2011 at 1:30 AM
  • CAR REPAIR CONTRIBUTOR
There are two different engine for these firing orders so I gave you both.
Check out the diagrams (Below)
Cheers
Mar 21, 2011 at 1:43 AM
FOURAM
What is the order and where can i find a diagram
Dec 25, 2020 at 9:13 AM (Merged)
See below
https://images.2carpros.com/forum/automotive_pictures/12900_fo_2.jpg
GEPIERRE
Engine Performance problem
1999 Mercury Sable 6 cyl Front Wheel Drive Automatic
Can you tell me the Spark Plug firing order for a 1999 Mercury Sable. I took the wire set off and don't know how to replace them correctly?
Dec 25, 2020 at 9:14 AM (Merged)
  • 54,334 POSTS
Hey GEPIERRE,
I found this guide for you that shows the firing order and the plug wire location.
Please let me know if you need anything else to get the problem fixed.
Best, Ken
RUTHLESSCUSTOMWORKS
1990 Mercury Sable 6 cyl Automatic
what is the correct firing order 1990 mercuy sable 3.8
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_145.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic3_67.jpg
