Thanks a lot but which of the 2 measurement that u gave me is it.052 or.056 wich of the two is it
Saturday, April 21st, 2012 AT 10:27 PM
MECHANIC
Gap it at.052 and get it over with
Saturday, April 21st, 2012 AT 10:37 PM
ZWAW JI GWAS CROW
MEMBER
1 POST
Which is the best spark plug gap to use to increase fuel mileage for 1997 mercury mountaineer.052 or.056?
Tuesday, April 25th, 2017 AT 5:30 AM
KEN L
MASTER CERTIFIED MECHANIC
That would depend on what the car calls for becasue it is very important when it comes to ignition timing.
Which is.052
Cheers, Ken
SPONSORED LINKS
Saturday, April 29th, 2017 AT 12:00 PM
SMITH7052
MEMBER
1 POST
1997 MERCURY MOUNTAINEER
V8
AWD
AUTOMATIC
150,000 MILES
Engine Mechanical problem
1997 Mercury Mountaineer V8 All Wheel Drive Automatic 150000 miles
the rear 2 sparkplugs have a sheild around them and one of them has been damaged so a socket want fit on the olug. Does anyone know how to get the sheilds off. Can't tell if they are pressed weilded or how they are atached.
Saturday, April 29th, 2017 AT 12:01 PM
(Merged)
RICKMAR
MECHANIC
The damaged shield is a heat shield. Here are the instructions of how to remove it. Once you have the shield off, It would be a good time to straighten out the damage as much as you can...WEAR GLOVES!!
Remove the wheel well splash shield.
Remove the exhaust manifold heat shield.
I HOPE THAT HELPED YOU.
Rick
(Merged)
ETHAN621
MEMBER
1 POST
Shakes or Wobbles problem
1997 Mercury Mountaineer V8 Four Wheel Drive Automatic
could old spark plug wires cause this
(Merged)
SERVICE WRITER
MECHANIC
Wobbles?
Does this symptom happen at idle while in park?
(Merged)
KEMPS
MEMBER
2004 MERCURY MOUNTAINEER
124,000 MILES
All the spark plugs went in without antisieze but im on the last one and it wont thread in and go on.
(Merged)
FIXITMR
MECHANIC
Did old 1 come out fine? I've had the issue where threads were bad/damaged on NEW plug.
(Merged)
KEMPS
MEMBER
Yes it came out fine and how can u tell if threads are bad, they look fine.
SPONSORED LINKS
Saturday, April 29th, 2017 AT 12:02 PM
(Merged)
FIXITMR
MECHANIC
It's tricky and dont take bein off much to cause problem. You could try that same plug in another hole? Also tr old plug in that hole it's not going into to be sure it's not damaged now too.
(Merged)
KEMPS
MEMBER
124,000 MILES
I got all the spark plugs on but one and when I checked them and pulled the other ones off they smelt like fuel. My last plug wont go on wont thread have checked them for debri and it isnt damaged or cracked or broke.
(Merged)
MECHANIC
IT may be stripped
(Merged)
CJ MEDEVAC
MECHANIC
TRY A DIFFERENT PLUG----EVEN PULL ONE OF THE OTHERS, AND TRY
EVEN NEW STUFF CAN BE MANUFACTURED WRONG
FRIDAY, 10 MINUTES BEFORE THE MACHINE OPERATOR CLOCKED OUT FOR HIS WILD WEEKEND!
I'M HOPING THIS IS THE CASE, AND YOU ARE NOT STRIPPED OUT!
THE MEDIC
(Merged)
MMPMARTIN
MEMBER
1 POST
2004 Mercury Mountaineer V8 All Wheel Drive Automatic
Where are the spark plugs located under the hood?
(Merged)
MECHANIC
2004 Mercury Truck Mountaineer AWD V8-4.6L SOHC VIN W
Hope this helps.
(Merged)
KEMPS
MEMBER
124,000 MILES
Have already gapped the plugs and all of them are in but one and I have cleaned debri ect. But it wont down at all.
(Merged)
KEMPS
MEMBER
Changed the spark plugs and drove to store had no problemS, then I when I went to start it the smorning it wouldnt start, just turns over, what could be causing that?
