2CarPros - Car Questions & Answers
2000 Mercury Marquis Repair Question
Topics covered: Sensor, Cylinder head, Engine.
Asked on November 5, 2010
2000 Mercury Marquis cylinder head temp sensor
Engine Cooling problem
2000 Mercury Marquis V8 Two Wheel Drive Automatic 59000 miles
trouble code p1285 cylinder head temp sensor. ran test on sensor and found that it was bad. replaced sensor and still have same problem. car dosent run hot car runs at 150 degrees and cylinder head temp sensor reads 248 degrees ohmed wires to ecm and checked ok. what else could it be do we need to have the ecm flashed.
Avatar Asked by bigoblock
Answer
Replied on November 6, 2010
if engine is running at 150 degrees then thermostat is bad. 150 is too cool , should be around 190 or so. remove and test thermostat.
Tiny Answered by bluelightnin6 (expert)
17,236 answers provided
