2CarPros - Car Questions & Answers
1989 Mercury Marquis Repair Question
Topics covered: Fuse, Trunk, Battery.
Asked on July 23, 2008
Circuits causing battery discharge at
Electrical problem
1989 Mercury Marquis V8 Two Wheel Drive Automatic 75000 miles
Circuits controlled by fuse # 8 (15amp) allow battery to drain overnite. Using a simple test light in series with + side of battery a bright light occurs. When # 8 fuse is removed bright lite disappears although a dim lite is shown & removing each fuse one at a time does not put out dim light. According to manual , circuit protected by fuse #8 is courtesy lamps,clock, autolamp module, illuminated entry module, outside power mirrors. I checked all lites & they seem ok for the go off when doors are closed. HOW DO YOU CHECK MODULES & WHERE ARE THEY LOCATED?
Avatar Asked by bill beville
Answer
Replied on July 23, 2008
glove box light? trunk light? courtesy light? how about vanity light in the visor? this is the stuff i find causing this problem, also radio wired incorrectly if it is a aftermarket radio. cigarette lighter element staying engaged a little bit? trunk light misadjusted causing light to come on with trunk shut?
Tiny Answered by mastertechtim
6 questions asked
