Help my car wont shift into gear
MZSHUGDA1
  • 1998 MERCURY MARQUIS
  • 6 CYL
My 1998 mercury grand marquis will not shift into gear from the park position once it is started. If the car is put into neutral and then started it can then be shifted but once put in the park position it again can not be moved. What is causing my car to get stuck in the park position?
Hay I need help please my car broke when I put it in reverse then when I tried to put it in drive it got stuck in neutral and the gear shift would just slide up and down. Luckly I broke down in front of a mechanic and he said something that connects to my transmission came disconnected I just need to know if you would have any idea of what the part was called I know it started with a D well if you have any idea of what the part is and possibly the price just let me know thank
Wednesday, March 16th, 2011 AT 11:39 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,833 POSTS
There is a shift lock solenoid that sounds like it has gone out or sometime has failing apart or the shift cable is having trouble. Use a test light to see if the solenoid is getting power
Here is a guide and a diagrams (below)
Please run this test and get back to us so we can continue helping you.
Cheers, Ken
Monday, June 5th, 2017 AT 5:54 PM
