2CarPros - Car Questions & Answers
2000 Mercury Cougar Repair Question
Topics covered: Ignition switch, Steering, Steering column.
Asked on April 11, 2010
2000 Mercury Cougar ignition switch
Electrical problem
2000 Mercury Cougar 6 cyl Front Wheel Drive Automatic 132000 miles
how to replace ignition switch
Avatar Asked by mike ramirez
Answer
Replied on April 11, 2010
1.Disconnect the negative battery cable.
2.Remove the 2 upper steering column cover screws and remove the cover.
NOTE
It is not necessary to remove the steering wheel for this procedure.
3.Remove the 3 lower steering column cover retaining screws and remove the cover.
4.Disconnect the electrical harness connector at the ignition switch.
5.Depress the locking tabs and remove the ignition switch.
To install:
1.Place the new ignition switch into position and push into place making sure that the switch is held securely.
2.Reconnect the electrical harness connector to the ignition switch.
3.Reinstall the lower steering column cover and its retaining screws.
4.Reinstall the upper steering column cover and its retaining screws.
5.Reconnect the negative battery cable.
6.Check for proper ignition switch operation.
Tiny Answered by bluelightnin6 (expert)
17,236 answers provided
