2003 Mercedes Benz SL500 Repair Question
Topics covered: Fuse, Blown fuse, Trunk.
Asked on April 5, 2010
2003 Mercedes Benz SL500 Blown fuse
Electrical problem
2003 Mercedes Benz SL500 V8 Two Wheel Drive Automatic 29000 miles
Lock system doesn't work .........I found a blown fuse which had blown previously and I replaced fuse
This time the fuse blows right away and I can't replace fuse
The fuse is a 20a located behind the passenger seat
Also now the top will not open and the message says "trunk separator open" but it is not
What would cause the fuse to blow, what can I check, is something jammed or is there a part that typically goes bad?
Does the top not opening have any relation to the problem?
Thank you
Thank you
