Mechanics
HYDRALIC OIL LEAKING FROM WINDSHIE
1999 Mercedes Benz 500sl
Interior problem
1999 Mercedes Benz 500sl V8 Two Wheel Drive Automatic 55000 miles
both sides started leaking at the exact same time. I was told that the units that hold the top down are both bad and need to be replaced. I can, t believe both went at the same time. Could there be some other problem?
Realmort
July 20, 2009.
Yes they can both leak, I have seen 129 chassis with all 6 rams leaking at the same time. Benz is pretty proud of the too. Good luck.
Car wizard
Aug 11, 2009.
