1991 Mercedes Benz 420sel
Brakes problem
1991 Mercedes Benz 420sel V8 Two Wheel Drive Automatic 310000 miles
I went to my car one day and started it. Brake fluid was coming from a rusty brake line. I called a wrecker and took it to my mechanic. He informed me that the brakes had locked up. Well he never worked on my car and told me I would be better off scrapping it. Since then I have replaced the rusted brake line, I also replaced two very old brake hoses and one brake caliper. Now that I have completed all that work. I learned that abs systems should not lock any of the wheels. My problem is that I have been working for several days to remove the air from the system to no avail. I have pumped and pumped away, I have opened the bleeder valves and gravity has not helped, I have removed the calipers and turned them up side down, I have used and vacuum pump and I still can not get the brake fluid to flow. Can you help?
May 12, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
