2CarPros - Car Questions & Answers
1985 Mercedes Benz 380se Repair Question
Topics covered: Clutch, Engine, Wheel.
Asked on February 24, 2009
1985 Mercedes Benz 380se fan clutch performance and how do
Engine Cooling problem
1985 Mercedes Benz 380se V8 Two Wheel Drive Automatic 220000 miles
Hi , i have replaced the water pump and thermostta 3 months ago. bearing shot , now all good. 2 weeks ago car developed overheating problem. when stationery in trafiic temp runs up to 110c , when on highway still running hot at 105 c. i have removed thermostat thinking may be flow blockage, but no difference. new fan belt on and firm. i have put a 2nd hand clutch fan on. seems to have much stronger air flow when idling. when i rev the engine the fan locks in and drives plenty of air then cuts back out again after 2 or 3 sec when car is stationary. How do i know if the 2nd hand clutch fan is working to specification? should the fan lock in and stay locked in or fall back to freewheeling when i rev the car in stationay position ? i am trying to understand the charatceristics of these fan clutches . new ones are very expensive like $1000 . I have flushed the water system and run descaling thru it . overheating problem still here. ta bruce
Avatar Asked by brucem
No Answer Yet
