2CarPros - Car Questions & Answers
2000 Mercedes Benz 320e Repair Question
Topics covered: Fuse, Battery, Engine.
Asked on May 31, 2010
2000 Mercedes Benz 320e climate control blower motor
Electrical problem
2000 Mercedes Benz 320e 6 cyl Two Wheel Drive Automatic 29000 miles
With the climate control fan button turned all the way down to off on the display & the ignition turned off the fan stays on & continues to blow air throgh the dash vents. I pulled the A/C fuses #4 & #7 out of the fuse box in the engine bay & the fan continued to stay on. I then pulled every fuse in the car out & replaced them one at a time [ in the engine bay under the rear seat & on the side of the dash ] with no luck the fan stays on. Now I'm getting two malfunctions ABS & BAS and the power window switches on the center console do not work this happened after I pulled & replaced all the fuses one at a time. So now the only thing I can do is to disconect the ground cable to the battery or else with the blower motor running no matter what I do would burn ot the motor or kill yhe battery. CAN YOU HELP ME OUT
Avatar Asked by kheyma
No Answer Yet
