1998 Mercedes Benz 300td Repair Question
Asked on January 21, 2010
1998 Mercedes Benz 300td Non starter
Engine Mechanical problem
1998 Mercedes Benz 300td 6 cyl Two Wheel Drive Automatic 202000 miles
Engine turns over but won't start.Lift pump faulty non return valve and repaired but unable to get fuel up through pump. Battery has been taken off and changed. Is there a system of re-setting the car through the key fob?
Answer
Replied on March 5, 2010
Make sure that the filter located by the pump at the bottom is installed correctly, look at the Aero make sure it is pointing in the right direction
