1994 Mercedes Benz 220cdi Repair Question
Asked on October 31, 2010
1994 Mercedes Benz 220cdi leaking injection Pump
Engine Mechanical problem
1994 Mercedes Benz 220cdi 4 cyl Two Wheel Drive Manual 200.00 miles
I have a mercedes C220D which is leaking from the top of the diesel injection pump on the top there are two pipes one from the filter and the other pipe
comeing from the back with a banjo nut also fitting to the top of the pump, there is also a square plate
on the top about4"x3" what gaskets do I need for it.
also if I do have to take the injection pump of what is the name of the locking tools and where can I buy them, and do I need any sealants, the wireing has four specail bolts do I need to undo these or is there
some release clips underneath as I haven,t looked Yet
I would really appreciate all advice offered Thank you.
from Trevor. I know the Pump must be taken off at
14.5 A.T.D. Centre
14.5 A.T.D. Centre
