2001 Mazda Tribute
Electrical problem
2001 Mazda Tribute 6 cyl Four Wheel Drive Automatic 104000 miles
2001 Mazda tribute electrical problem. I have the above car and it is giving me big problem as the battery easily runs out. The mechanic have advised change of alternator; this have been done thrice still problem persist.
Earlier he informed that he has fixed the problem; he discovered a damaged relay with its cables fused together.
The problem actually damages the alternator hence the replacement.
The battery lasts longer when I use the car without the A/C on. Once A/C is used, the battery doesn't last more than one hour.
I have also noticed there is a sound at the ignition once you match the break pedal while the key is in the ignition (idle).
May 20, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
