2CarPros - Car Questions & Answers
1999 Mazda Protege Repair Question
Topics covered: Engine, Battery, Check engine light.
Asked on August 15, 2008
1999 Mazda Protege Check Engine Light Coming On
About 2 months ago I purchased a used Mazda Protege from a family friend. She had everything on it safetied and brought the car into Mazda for an engine test where they said everything was in really good condition. About a month after having it, the Check engine light came on while I was driving. Just to make sure, we unplugged the battery so it would reset, the light went away, but came on again in about 2 weeks. The car sounds great, starts great, all the fluids have been checked and double checked, the filters were just replaced before I bought it so is this just a sensor problem or should I be spending the money to take it in and get it checked?
Avatar Asked by Jordoe28
Answer
Replied on August 15, 2008
take it to autozone, have the code scanned and get back to me.
autozone will scan for free!
post the code, not what the code means.
Tiny Answered by blackop555 (expert)
10,902 answers provided
I would but I live in Canada and we don't have an autozone here .
I will call around and see if I can find a place to scan for free and get back to you. Thanks
Tiny Response from Jordoe28
2 questions asked
Replied on August 22, 2008
you can also start by performing a quick visual inspection, look to make sure that no connectors are disconnected under the hood, also make sure that the gas cap is tight and the sealing surface is clean. let us know how it's going eh.
Tiny Answered by xowey
1 question asked
Replied on August 23, 2008
Well so far, since unplugging the battery and reseting everything, the engine light has not come back on. I started a Trip to record my mileage this time and so far I've driven 379 miles. However when it does come back on, like it did the previous times I resetted, I will take it in and get back to you guys. Thanks
2 questions asked
Replied on August 24, 2008
doesnt sound too major in that case as it should be coming back on right away, when ever its your convinence i would take and have it looked at, just in case.
Replied on August 27, 2008
I am now at 600 miles and the Check Engine still has not come on after I reset it. Today I did however go to Mr. Lube to get an oil change. They also check everything and the only thing that they noticed was my PCV Emission valve was really plugged .. so they replaced it for 12 dollars.
Could it of been the PCV valve being plugged causing the engine light to come on?
2 questions asked
yes that can cause the problem! it can cause the fuel mixture to show as lean or rich. and can also mess with the idle!
Thank you! That is good to hear and I hope that is what was happening.
2 questions asked
i wish you luck.
Replied on September 1, 2008
Alright so at 1093 miles, the Check Engine light has finally returned. I guess I will bring it in to get it checked out.
2 questions asked
