Car will not start. The engine turns over but that is it. I suspect a fuel system problem. Fuel pump appears to have plenty of pressure. A Noid light indicates that the injectors are firing. Checking a spark plug, it was dry. There appears to be a spark. I currently suspect the fuel pressure regulator. The fuel rail has fuel flowing through it but I cannot tell if it is pressurizing.
Oct 8, 2010 at 12:43 AM
