Mechanics
WILL CRANK BUT WILL NOT STAY RUNNING WHEN
1994 Mazda b4000
Engine Performance problem
1994 Mazda b4000 6 cyl Four Wheel Drive Manual 250000 miles
The problem I am having is a running problem. It only occurs when the engine is hot, and is an intermittent problem. After I drive the truck for a while and cut it off to go in a gas station or store for 10 minutes or soo it will not run. It turns over and trys to run but cuts right back off. It does not do it when the engine is cool, like in the mornings when the truck has sat overnight or anytime the engine is cool after sitting a few hours. It cranks right up and runs fine. Any suggestions? I am very capable of fixing it myself, but I just cant seem to figure this one out. I thought it might be the ignition mudule because it was mouted right beside the radiator where it gets hot, soo I moved it away from the heat, but the problem still exists. Just hoping for an answer to this problem,
Thanks, Cody
Codyman1107
July 23, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
