2CarPros - Car Questions & Answers
1994 Mazda b4000 Repair Question
Topics covered: Engine, Sensor, Rpm.
Asked on April 7, 2010
1994 Mazda b4000 Engine No Power
Engine Performance problem
1994 Mazda b4000 6 cyl Four Wheel Drive Manual 190000 miles
I have a Mazda B4000 and from a few months I saw me as the power of the engine decrease. I have much less power when the engine is on load. I also notice that the relationship speed/rpm is not the same. At first, in 2000 rpm, I drove 110 km / h and now at 2,000 rpm , I drive 90 km / h. Even if the check engine light does not turn on, I suspect the MAF to be responsible. What do you think?
Thanks, any help would be appreciated Vincent
Avatar Asked by vynce
Answer
Replied on April 8, 2010
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Tiny Answered by rasmataz
68 questions asked
