2003 Mazda b3000
2003 MAZDA B3000
96,000 MILES • 6 CYL • 2WD • MANUAL
JNOLES
I have only been driving manual transmission vechiles for two years so I am not to familiar with the operation of manual transmission. On morning I was driving to work and I shifted in to first then sceond and then I stop and put it in neutral. I went to start up again an my clutch pedal went flat I was unable to shift into any gear. I have had no problem shifting prior to this. Anyone have any ideas
Jan 24, 2009 at 7:34 AM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Hi JNOLES,
When the clutch pedal sinks, you need to check the clutch fluids and if it is low, you might have a leak somewhere or the clutch master or slave cylinder is bad.
Jan 24, 2009 at 10:53 AM
