1997 Mazda b2300
Engine Performance problem
1997 Mazda b2300 4 cyl Two Wheel Drive Manual 246040 miles
sorry, but I have a problem with this truck, fuel pressure is ok ( 35-45 psi ), engine compression ( 150 psi ) in each cylinder, exhaust system ok, ( no catalytic converter installed to test ), coils ok ( spark in 8 spark plugs ), charging system ok ( 14.25 v ) idle, timing belt sychronizing ok ( crankshaft gear/camshaft gear match timing points ), new fuel filter, no fuel restriction, no cracks in mass air flow, firing order for 8 spark plugs ok, and I still have NO POWER, new clutch system, the truck start ok, but ther is no power, no hard fault codes, tps sensor range ok, could you give me an idea what's going on with this problem, PLEASE.
June 25, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
