1994 Mazda b2300
Transmission problem
1994 Mazda b2300 4 cyl Two Wheel Drive Manual
I am in the process of replacing a friends clutch in his truck I replaced the fly wheel the pressure plate the friction plate and the slave cylnder the only thing I didnot replace was the master cylender and pressure line after installing everything I bench bled the master and gravity bled the release valve on the slave but the clutch would not engage and the pettle was not working properly it had a little slack at the top then got real stiff. I pulled the master cylnder off again and noticed that if I pushed the open close valve on the end of the pressure line and prested the piston it seemed like it eas working correct do you think it is a bad connection on the pressure line to the slave or could it be something else your help would be appreciated
March 28, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
