1987 Nissan Stanza oil leaking into my cooling system
1987 NISSAN STANZA
89,996 MILES • 4 CYL • 2WD • AUTOMATIC
2CP-ARCHIVES
  • 4,540 POSTS
1987 Nissan Stanza mileage: 90,000. I have oil leaking into my cooling system. I had a compression test and everything checked out ok, so I guess it's not a leaky head gasket. Any other ideas?
Nov 9, 2010 at 2:58 AM
2CP-ARCHIVES
  • 4,540 POSTS
The compression check that you did may not have eliminated the head gasket as a possible source of your oil leak. Your symptoms would indicate that the head gasket is causing your problem. We would take the head off and inspect the gasket here.
Nov 9, 2010 at 2:59 AM
