fuel filter
1999 MAZDA 626
175,000 MILES • 4 CYL • FWD • AUTOMATIC
BBPHISH8989
i have a 99 mazda 626 4cyl and i was wondering where the fuel filter is located?
Jan 23, 2011 at 11:13 PM
  • CAR REPAIR CONTRIBUTOR
The fuel filter is located under the hood on the drivers side here is a guide and diagrams below to show the location and how to change it out.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Cheers
Jan 23, 2011 at 11:15 PM
BETTERSJEFF
Where is my fuel filter location? I want to do a tune up and include replacing the fuel filter.
Oct 1, 2018 at 11:19 AM (Merged)
REMOVAL
Release fuel pressure.
See: Fuel Pressure Release
Disconnect the negative battery cable.
Remove the air cleaner and air hose.
Remove in the order indicated in the table.
DUCKSTER1
2000 Mazda 626 4 cyl Front Wheel Drive 135000 miles
where is the fuel filter located on the said car. In order to replace it do I have to put it on ramps to get to it ?
SRAZEY89
its located under the air filter it has a hose that comes out of the top of it easy to find
MRS. B
Mazda 626 1992 fuel filter in gas tank?
Left rear engine compartment. A filter screen on fuel pump inlet removes larger particles.
2CP-ARCHIVES
  • 4,540 POSTS
1998 Mazda 626 mileage: 142,000. What exactly do I do to fix the car if someone accidentally put diesel instead of gas in the tank and drove a couple miles until it stopped? Where is the fuel filter?
2CP-ARCHIVES
  • 4,540 POSTS
The fuel filter is probably in the rear of the car by the fuel tank. Now, on to the diesel problem. Remove as much diesel fuel as possible from the gas tank and refill it with gasoline. You may have to crank the car to purge the diesel fuel out of the fuel lines. After that, it should start and run okay and there shouldn't be any damage to the engine from the diesel fuel.
CLABRUYERE
I have a 1996 Mazda 626-V6 with a 135,000 miles.
Where is the fuel filter located?
Thank you!
COSMO
  • 347 POSTS
Under the air box on the driver side.
Good luck if you have a V6 auto with ABS!
I give it to my apprentices for a "learning experience" LOL
Cosmo
Mazda TEch
p.s. I hope you have thick skin
LUNASHELL
on 2001 mazda 626 4/cyl. Where is the fuel filter located?
BLUELIGHTNIN6
  • 16,542 POSTS
Under hood, driver side, engine side of strut tower, below air filter housing, mounted in fuel line
MCQUAID
could you tell me where the gas filter is located,and the maf thank you.
ZACKMAN
  • 4,202 POSTS
Fuel filter is close to the driver side firewall, next to your EVAP canister.
MAF sensor is located on your air filter hose, in between the air filter box and throttle body.
CUTZUP
I need to change the fuel filter. Can you tell me where it is located on the car?
AER
Engine Mechanical problem
1997 Mazda 626 6 cyl Automatic 172000 miles
I am overdue to change the fuel filter and my car has been running poorly for a bit now. I showed all the symptoms of needing a new filter but I procrastinated. My car stopped while driving as if it had run out of gas and now will not start even though I have half a tank of gas in it. I am hoping it is not the fuel pump, is it possible that the old fuel filter caused this and changing it would get my car running again?
Oct 1, 2018 at 11:20 AM (Merged)
DAVE H
  • 13,384 POSTS
Check for fuel pressure .. the filter is located on pump assembly inside the tank ! FUEL PRESSURE Fuel Pressure Hold Disconnect negative battery cable. Install fuel pressure gauge in fuel supply line. Reconnect negative battery cable. Locate data link connector in left side of engine compartment. Connect a jumper wire between data link connector terminals F/P and GND. See Fig. 1 . Turn ignition on for 10 seconds to operate fuel pump. Turn ignition off and disconnect jumper wire. Wait 5 minutes and observe fuel pressure. Fuel pressure should be at least 21 psi (1.5 kg/cm2 ). If fuel pressure is not as specified, check fuel pump hold pressure and fuel pressure regulator hold pressure. See FUEL PUMP HOLD PRESSURE and FUEL PRESSURE REGULATOR HOLD PRESSURE headings below. Also check for injector fuel leakage.
https://images.2carpros.com/forum/automotive_pictures/266999_maz_1.jpg
R SEVERSON
2000 Mazda 626 4 cyl Two Wheel Drive Automatic
whre is the fuel filter on the mazda 626 2000 4 cylinder 2.0 automatic
ZACKMAN
  • 4,202 POSTS
Close to your brake master cylinder, on the driver side firewall. If you have the original fuel filter, it is black. You may have to move some wiring out of the way a bit, it might be buried underneath them.
MR. BURCH
Where do i install the fuel filter?
BLUELIGHTNIN6
  • 16,542 POSTS
Under hood, driver side, rear engine area, driver side of master cylinder, mounted on front side of strut tower
