2CarPros - Car Questions & Answers
1983 Mazda 323 Repair Question
Topics covered: Engine, Rattle, Compression.
Asked on September 17, 2009
The ecu is ticking and engine rpm is fluctua
Noises problem
1983 Mazda 323 4 cyl Front Wheel Drive Manual 99999 miles
when i received the car alot of vaccume hoses were missing. i had them corrected and the engine was running but had low compression in cylinders 2&3 also cylinder 3 was not firing, (injector fault)
the engine, running on 3 cylinders had a rattle.
the ecu soon started to tick and the rpm would die off or increase. i am having trouble finding a solution to this.
the engine rattle increases as the revs do.
the ecu ticks and the revs fluctuate from idle.
Avatar Asked by curmett
No Answer Yet
