Mechanics
LOW IDEL WHEN COMING TO FULL STOP CAR
1987 Oldsmobile 98 • 127,000 miles
Low idel when coming to full stop car
Hello:
I have 1987 oldsmobile 98 regency brogham with 127,000 miles on it.I replaced the following.
1. New battery
2. A new Alternator
3. New battery cables.
4. New Spark Plugs
5. New idel air control
6. New icm Ignition Module
7. New ecm compter control module with a new eprom for gm vintage warehouse
8. The car now has no codes from the computer. AFTER IT WAS INSTALLLED
9. Rebuild tranmission
after a few hours driving, the idle is rough and wants to stail out,
the car has 3.8 L 213 CID V6 General Motors engine
is there any others sensors that could case this problem
how about egr value & tp sensor
I NEED HELP WITH THIS PROBLEM
ALSO THE GAS MILAGE IS very bad & gas smell from tail pipe after car is parked.
THANK YOU
AD
Blackoldsmobile 98
July 1, 2013.
Clean throttle plate on both sides with choke cleaner and iac hole. Check fuelpressure shold be 41-47 psi
Hmac300
Jul 2, 2013.
AD
