Mechanics
THE POWER TRUNK PULL DOWN HAS STOPPED
2003 Lincoln Town Car
Electrical problem
2003 Lincoln Town Car V8 Two Wheel Drive Automatic
I've got the fault code B1342 ECU IS FAULT - don't know where it's located and if its need to be replaced or what.
When I close the trunk by hand the trunk is closed the last bit.
I can only open the trunk with the key.
I've tried to reset the trunk (disconnect the battery with the trunk closed, and connect it again. Press the open button on the door and then open it with the key, open it fully, then press the open button again and then close it by hand).
I can hear a click inside the door when I try to open or close the trunk with the open buttons.
I've checked all fuses,
The adjustable pedals doesn't move, I don't know if they are on same loop or what.
And I don't have any light inside the trunk when I open it (I've checked the bulbs).
Any suggestion what to check?
Thanks
AD
The Owner
August 12, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
